1994 Buick Lesabre
CHEVYMIKE1014
Engine Mechanical problem
1994 Buick Lesabre 6 cyl Front Wheel Drive
My car will sart but stops as as soon as i hit the gas
Jan 16, 2009 at 12:27 PM
KEVIN12881
  • 336 POSTS
miles??? have you tuned up recently or on time? check these Engine lacks power... See one of the following: 1.) Incorrect ignition timing. 2) Fuel filter clogged and/of impurities in fuel 3) Faulty or incorrect gapped spark plugs. 4) Air filter dirty. 5) Spark timing control system not working properly. 6) Faulty ignition coil(s) 7) Brakes binding. 8) Auto Trans fluid not correct 9) faulty distributor cap or wires 10) EGR system not functioning properly. 11) Use of sub standard fuel. 12) Low or uneven cylinder compression pressures 13) Air vacuum leak at intake manifold or plenum
Jan 16, 2009 at 12:35 PM
