Hello first thing is to check for spark the module that controls the spark maybe tied in with the injector pluse or crank sensor might be bad and if all is ok, check PCM that also controls the injector pluse which is located in the car on the passenger side kick panel. If there is a bad ground this will also cause it not to fire. Hope this will help you.
Jan 6, 2020 at 7:40 AM
