1993 Buick Lesabre stalling
DRUMMER123
Engine Performance problem
1993 Buick Lesabre 6 cyl Automatic
I have a car that stalls when i turn sometimes, usually when it dies i can start it back up asap, while its still rolling and then keep going, ive been told theres a crack in the pickup line in the tank and if i keep it full and it dont get to a certain point on the gage it wont do that, can anyone help with any info?
Jun 24, 2009 at 10:37 AM
  • 110,251 POSTS
If that is correct, does the car run out of gas at, lets say, 1/4 of a tank? If there is a problem with the fuel, you can check it by doing a fuel pressure test when the fuel gets low in the tank. If you have 1/4 tank and the car will no longer run, check for pressure. Here is the how to:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Jul 13, 2009 at 3:44 PM
