1993 Buick Lesabre speed related wobble
1993 BUICK LESABRE
MBREEN1
Shakes or Wobbles problem
1993 Buick Le Sabre 6 cylinder Front Wheel Drive Automatic 183000 miles
As I increase speed, the front-end wobbles and a speed related rumble becomes louder. I can feel it in the steering wheel and hear it. However, when I turn slightly, the rumble and wobble go away until I straighten the wheel and they return. Where do I look for the problem? Thanks
Apr 23, 2008 at 1:20 AM
SERVICE WRITER
  • 9,123 POSTS
Check the wheel bearings first for play. Raise it up in the air on a lift and listen to the bearings with a stethoscope.
Apr 29, 2008 at 2:06 AM
  • 55,224 POSTS
Hey MBREEN1,
IF the bearing seem okay, It could be a tire problem, can you rotate the tires front to back to see if that helps?
May 4, 2016 at 5:07 AM
