I am trying to find out where and how to replace my ignition switch on my 1993 Buick Lesabre?
Oct 30, 2008 at 12:16 PM
2CARPRO JACK
✓Experienced Mechanic
Should be on top of the stereeing column about 2/3 of the way down. It mounts to the top of the column with 2 small bolts and there is a rod that operates it (can be seen when switch is removed).Sometimes itis easier to get to it by lowering the column down a little
Oct 31, 2008 at 1:24 AM
DIRTYGERTIE
MEMBER
I'm sorry, I already knew that, but do I have to take the steering columm apart?
Oct 31, 2008 at 11:01 AM
2CARPRO JACK
To replace the igniton switch no, to replace the key tumbler yes. If you unbolt the column and let it come down a little you can get to the switch
