I am trying to find out where and how to replace my ignition switch on my 1993 Buick Lesabre?
Thursday, October 30th, 2008 AT 7:16 PM
2CARPRO JACK
MECHANIC
Should be on top of the stereeing column about 2/3 of the way down. It mounts to the top of the column with 2 small bolts and there is a rod that operates it (can be seen when switch is removed). Sometimes itis easier to get to it by lowering the column down a little
SPONSORED LINKS
Friday, October 31st, 2008 AT 8:24 AM
DIRTYGERTIE
MEMBER
I'm sorry, I already knew that, but do I have to take the steering columm apart?
Friday, October 31st, 2008 AT 6:01 PM
2CARPRO JACK
MECHANIC
To replace the igniton switch no, to replace the key tumbler yes. If you unbolt the column and let it come down a little you can get to the switch
