1993 Buick Lesabre Intermittently runs.
12,000 MILES • 6 CYL • FWD • AUTOMATIC
DIRTYGERTIE
  • 9 POSTS
We have changed all fuel components due to engine cranks over, sometimes it starts sometimes it does'nt. You can drive it, but cannot trust it due to engine dying and then will not start, but will crank over. You can hear if the fuel pump kicks, sometimes it does, sometimes it does'nt, we have replaced the fuel pump. Thinking this could be ignition module, or EGR valve, I have to say no, if these were to go bad they completely die and go bad, not intermittently. Could someone maybe narrow this problem down a little better?
Aug 21, 2008 at 5:13 AM
SUNHEADRED
i had the same thing. mine would not start after shut off. had to wait till car cooled down than would start mine was ignition moduale. still runs 2 years later hope this helps
Aug 28, 2008 at 2:29 PM
