1993 Buick Lesabre fluid low, leaking?
TRBATTAH
Transmission problem
1993 Buick Lesabre 6 cyl Front Wheel Drive Automatic 139k miles
I was driving my car the other day and the transmission started making an awful noise and then started moving very slowly. I pulled out of the way and checked the fluid. It was very low. My son brought me 2 qrts to put in. I managed to drive the car almost home with no problems. about a block from the house it started in again. I am hoping that I just need to add more fluid and it is not needing a new trany. Also, I do not see any signs of it leaking anywhere. I just lost my job the same day this all happened. I am praying for the least expensive way here. I need my car before I can get a job.
thank you for your time and answer
Tonya
Mar 18, 2008 at 3:21 PM
BMRFIXIT
  • 19,053 POSTS
If it drove fine for you after you added the ATF fluid then I would say you may have a leak in the system and need to be checked
check the cooler line
good luck
Mar 27, 2008 at 2:46 PM
