1993 Buick Lesabre engine
160,000 MILES • 6 CYL • FWD • AUTOMATIC
KAZDA6
when first starting engine. i have a rough idol & can smell gas, also blue or white smoke. after a few minutes everything goes back to normal and engine runs fine
Feb 27, 2009 at 6:33 AM
ZACKMAN
  • 4,202 POSTS
You should perform a compression test, at the very least. You have your gas mixing with oil. That the smoke you see and the gas smell. You should also check the fuel pressure at the rail, just to make sure the fuel pressure regulator is holding the correct pressure.
Feb 27, 2009 at 12:59 PM
