1993 Buick Lesabre car stalls in drive not in reverse
GTOWN76
1993 Buick Lesabre 6 cyl Automatic
My baby smoothly stalls in drive, no stumbling or idling down. It operates normally in park,neutral, and reverse. Two weeks before it started the car would intermittently stall when accelerating from a light. Before anyone suggests the tcc, is it possible for it to stall the engine in all drive gears and not in reverse.
Apr 15, 2008 at 1:38 AM
DENNYP
  • 1,824 POSTS
check it for trouble codes. It could be the MAF sensor. The tcc should stall in reverse also if it's bad.
Apr 20, 2008 at 12:26 AM
GTOWN76
the voltage readings from the maf were at 2.43 at idle, but drop to 2.35 with throttle applied. Is that normal??
Apr 22, 2008 at 6:17 AM
DENNYP
  • 1,824 POSTS
If you look through the MAF sensor, is it really dirty or does it look like it's melted? If so, you should probably replace it.
Apr 22, 2008 at 3:08 PM
