1993 Buick Lesabre Blower Motor Malfunction
90,000 MILES • 6 CYL • FWD • AUTOMATIC
TNTBRIG
When I access the climate control unit, the car makes sounds when hitting different buttons but no air is being blown. Volt-tested the plug into the blower motor, and registers 12v. A friend "hot wired" the blower from a battery charger at 12v and the blower DID come on. All fuses are intact. Am confused that the blower works but plug delivers 12v. Thanks!
Jul 9, 2008 at 3:01 PM
  • 75,988 POSTS
Problem cpould be th HVAC control module or the blower resistor -
Jul 9, 2008 at 3:07 PM
TNTBRIG
Thank you so much. How do I check these?
Jul 9, 2008 at 3:17 PM
  • 75,988 POSTS
Sir if you're not electrically incline seek professional help this is not a simple thing to do or for us to guide you thru its not that easy -Sorry! get the blower resistor checked out 1st-this is the one that controls the blower motor speed by increasing and decreasing resistances in the circuit-
Jul 9, 2008 at 3:42 PM
