1993 Buick Lesabre
RAINMELLO
Electrical problem
1993 Buick Lesabre V6 Two Wheel Drive Automatic 178000 miles
Panel push button for heat. When pushing on it will not come on but run through every choice there is and stop on what it wants. I hear clicking behind the glove box when it does this. At times the door locks will not work but not often. I dont have a problems with light or radio or windows.
Now it will when turned key off will not start back up right away everything will be dead. No clicking, no lights If I jump it it starts right up. If I wait for couple hours then it will start. Please help Im at a loss. I do most of repairs myself because I always get ripped off because I am a women.
Dec 5, 2007 at 1:29 AM
FISHERMAN
  • 937 POSTS
[quote:ff2b0e9c8d="dave1010"]I have recently changed my engine in my land rover series II. For a rover 3.5 V8. I have 12volt going to the coil + terminal but have 0.12 volts from the coil - terminal. Have have checked the coil on another car and it works fine. I have also fitted new points and condenser. But still have no spark from coil HT lead...
Can anyone help me with this.. :?[/quote:ff2b0e9c8d]
Hello Dave !!
Well, first at all check the ground wire to the base of the points and make sure that the gap on the points are adjusted right...
and the points wire that goes out be insulated from touching the ground of the distributor body..
That`s the basic...
let us know after you check that..
Oct 11, 2007 at 5:27 AM
FISHERMAN
  • 937 POSTS
Hey Dave !
Something else ...
Use a test light with the (+) of the coil on one end and the negative side of the coil on the another....
the test light should be On-Off-On-Off (blinking when cranking but off when not cranked) that way we know for sure that the points and condenser are both good..
let us know to continue with the troubleshooting..
Oct 11, 2007 at 5:37 AM
