1992 Buick Lesabre want start
JAMESHAWN
Engine Mechanical problem
1992 Buick Lesabre 6 cyl Front Wheel Drive Automatic
the car was driving fine and the next day it want start.acks like it is not getting gas.
light is flashing on the dash,the light says,infl.and under the light it says,rest
Jan 4, 2009 at 3:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The lights that are illuminated indicate that the air bag computer has stored a trouble code. I wouldn't think that this is related to your starting issue, unless it is your computer that is faulty which would cause no start.
You will have to test fuel pressure at the fuel rail and also check spark at the plugs . Post which one the engine is not getting. If it is both then the computer probably needs replacing.
Hope this helps..
Thanks for using 2carpros.com!
Jan 4, 2009 at 4:08 PM
