1992 Buick Lesabre Rough idle when warm
140,000 MILES • 6 CYL • FWD • AUTOMATIC
PAUL2BEC
when I try to start the car for the first time in the morning, it shuts right off, then the 2nd time it will start. runs good until it warms up then the idle is rough and when you shift it to reverse or drive the idle drops real low and sounds like it wants to die. once your moving it runs great
Feb 13, 2009 at 1:04 PM
MERLIN2021
  • 17,250 POSTS
Can be several problems, first, when was the last complete tune up? Filters? Wires? Then check for Vacuum leaks, use a can of spray throttlebody cleaner, spary around vac lines and intake manifold, if the speed of the engine changes, you found a leak, fix it! Then if the check engine light is on, read the codes. The IAC(idle air control) manages the idle air intake, it's bolted to the throttle body, and could be the problem.
https://images.2carpros.com/forum/automotive_pictures/62217_CRC_Throttle_Body_10.jpg
Wouldnt hurt to clean out the throttle body!
Feb 13, 2009 at 11:14 PM
