1992 Buick Lesabre po 41 engine code.
CHARS83
  • 1992 BUICK LESABRE
Engine Performance problem
1992 Buick Lesabre 6 cyl Automatic 210000 miles
How do you test to see if you may have a bad ignition module or cam sensor.
Wednesday, March 18th, 2009 AT 8:35 PM
BILLYMAC
  • 2,204 POSTS
You can test the cam sensor for a 5 volt reference comeing from it to the module. If you have a 5 volt ref comeing to module and not back out module is bad. You can avoid all this just by haveing them tested at a local parts store
Monday, March 30th, 2009 AT 9:01 AM
