1992 Buick Lesabre harmonic balancer bolt
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
TKY
we cant get the harmonic balancer bolt out to repair front main seal leak
May 6, 2008 at 2:10 PM
  • 75,988 POSTS
Either you drop the starter and jam the flexplate or use a long breaker bar brace it properly underneath-clear out of the way and crank engine over this will loosen it-or you can try an impact wrench-
May 7, 2008 at 9:41 AM
BUZZSAW
  • 1,198 POSTS
[quote:83a139e216="rasmataz"]Either you drop the starter and jam the flexplate or use a long breaker bar brace it properly underneath-clear out of the way and crank engine over this will loosen it-or you can try an impact wrench-[/quote:83a139e216]
also be careful of the crank sensor
May 7, 2008 at 3:08 PM
