1990 Buick Lesabre pcv value
259,000 MILES • 6 CYL • FWD • AUTOMATIC
ASBESTOS
my engin is running rough on take off and when trying to hold a steady speed, i am going to change the fuel filter and the pcv value its got new plugs in it, But i cant find the pcv value there is only a hose going into the valve cover is there suposed to be a pcv value there as well and its just missing?
Aug 10, 2008 at 12:01 PM
BLACKOP555
  • 10,386 POSTS
you dont have a pcv valve there
that hose is the breather for the crankcase.
instead of a pcv valve you have a calibrated orifice. doesnt need replacing and wouldnt be causing your problem.
you would notice a bad idle.
Aug 10, 2008 at 2:18 PM
