1990 Buick Lesabre hhheeellllpppp
135,000 MILES • 6 CYL • FWD • AUTOMATIC
BDEAVERS
i have a 90 buick lasabre that i have been working on for a week now. i am an intermediate mech., spent some time working in dealerships, so i am knowedgeable on mechanic work. it is stalling on me going down the road, sometimes after long drives and sometimes after a very short drive. first i replaced plugs, wires and fuel fillter. then when that didn't fix it, i checked the fuel pressure. with a fuel pressure guage connected, i'm getting 43 psi w/ key on which is spec, so it's not a fuel pump. i checked for spark at the wires and nothing, so i replaced the coil pack and had the ignition module tested at the parts house and it passed. so i went to the crank sensor and replaced it, and after that it drove great for about 10 miles, then stalled again and will not crank. when it stalls and won't crank, i'm not getting fire, but when the car does work, i have spark, so something is cutting my fire off, what's left?
Mar 13, 2008 at 4:11 PM
GURANKO
i have had the same issue with my buick. i found out that if any bare wiring hits the engine it will shut down and will not crank. also check your fuses behind your glove box. the middle one is the one that activates the coil pack.
Apr 20, 2008 at 1:10 PM
