REVS REALLY HIGH - HIGH THROTTLE, WON'T KICK DOWN - WHAT IS THE PROBLEM? JUST GOT CAR FROM FAMILY, NEED TO FIX PROBLEM.
May 19, 2008 at 2:27 AM
MASTERTECHTIM
✓Experienced Mechanic
most common problem is a bad idle air control valve. also clean the throttle plates with carb cleaner and a clean rag. **make sure the linkage is not stuck
