1990 Buick Lesabre engine stalling while idling after runni
173,300 MILES • 6 CYL • 2WD • AUTOMATIC
CHRIS WARD
My car will run good on the highway until I get somewhere and it's sitting idling. It'll start running rough and stall out. Sometimes it'll start right back up sometimes I have to let the car sit for awhile. I've replaced o2 sensor,throttle position sensor and idle air control valve fuel filter still doing same thing I'm stumped! I do a driving mail route it'll start out good then about an hour into the route it starts stalling out. Help.
Mar 6, 2008 at 12:43 PM
CHRIS WARD
I figured it out the it
was the crank shaft sensor.
Mar 7, 2008 at 10:13 AM
NJB325
so how is it running now? Same problem for us, but first replaced throttle position sensor and was told O2 sensor bad too, replaced O2 sensor but car was "coughing" more with new O2 sensor, took out new and put back old and problem even worse, haven't tried idle air control or crank shaft sensor yet..........let me know. thanks
May 22, 2008 at 1:59 PM
