1990 Buick Lesabre Acceleration
DELTA_88
Engine Performance problem
1990 Buick Lesabre 6 cyl Front Wheel Drive Automatic
When I give the car gas, it seems like it isn't getting enough gas. It starts making a popping noise and cuts back. Sometimes it will graduadlly go, but not like it used to. Other times, it will just start popping and not do anything. Any help would be GREATLY appreciated!!!!!
May 3, 2008 at 12:42 PM
NJB325
have gotten any feedback? have the same car with same problem...thanks
May 22, 2008 at 1:40 PM
RHONEY22349
  • 13 POSTS
Sounds like you need to pull the spark plugs and do a compression test. This would eliminate the possibility that it is a bad valve in one of the cylinders making this sound through the exhaust or the intake.
Jun 3, 2008 at 2:32 PM
