1988 Buick Lesabre Fuel pump
CHRISTINEH03
  • 1988 BUICK LESABRE
Electrical problem
1988 Buick Lesabre 6 cyl Front Wheel Drive Automatic
yess the car situp for about a year, the fuel pump will come on but it doesn`t let much fuel come out was wondering could tthe strainer be keeping the fuel from going to the injectors. Cause the car will not stay running when u do get it cranked!
Tuesday, August 17th, 2010 AT 1:47 PM
WRENCHTECH
  • 20,761 POSTS
Unless the inside of your fuel tank is completely trashed and rusted out, the strainer is not going to be your problem. It's most likely just a bad fuel pump but you need to test this using a fuel pressure gauge. You may have to cycle the key on a few times because it only powers for 2 seconds on every key cycle.
Tuesday, August 17th, 2010 AT 1:53 PM
