Engine Performance problem
1985 Buick Lesabre 6 cyl
gentleman: 85' Buick 4.1L 252 v-6.HEI distributor. I bought book for info and on timing it says: look on label under hood for timing info. this engine is in an airboat. What are the degrees of timing for this motor? And is that with the vacuum line disconnected or plugged? thanks for the torque sequence I reguested the other day with torque specs. Don
Jan 12, 2009 at 11:05 AM
