1971 Buick Lesabre ignition problem
ALLOVER81
Engine Mechanical problem
1971 Buick Lesabre V8 Two Wheel Drive Automatic
when I turn the key to start the car it starts up but when I let the key go it turns off.. WHY? I changed the spark plugs, fuel pump, starter, ignition switch. it is getting gas in the carb.
Aug 7, 2008 at 11:32 PM
JDL
  • 16,098 POSTS
This almost sounds like a resistor problem. I don't have a wiring diagram for this vehicle. I'm not sure if there is a resistor for the coil circuit on this vehicle.
Leave the key in the on position, see if there is B+ at the coil.
Aug 8, 2008 at 1:17 AM
