2008 Buick La Crosse Tail Lights
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
MJEMINHIZER
i believe my turn signal(rear passenger) is out. how do i remove tail light to raplace bulb?
Feb 13, 2010 at 4:32 AM
  • 110,251 POSTS
Open the trunk, and remove the carpet which covers the tail light assembly. Once you do that, remove the plastic wing nuts from the assembly and it will come out. THen you can access the bulb.
Mar 4, 2010 at 2:47 AM
