2006 Buick La Crosse Erratic Remote
51,000 MILES • 6 CYL • FWD • AUTOMATIC
JSGRAHN
Several weeks ago the remotes for my 2006 Lacrosse began working erratically. I rplaced the battery in each unit. Now the alarm goes off for no apparent reason. It got so bad that I removed the fuse for the horn. Now the exterior lights have started to flash for no apparent reason. What's causing this and how can I fix it. Thanks.
Sep 19, 2009 at 11:33 AM
BRIAN 1
  • 1,030 POSTS
have to check the inputs from each door switch with a scan tool.could be a faulty door switch.
Sep 19, 2009 at 12:33 PM
