Low brake fluid indicator
ANDFAM
Brakes problem
2005 Buick La Crosse 6 cyl Front Wheel Drive Manual 60K miles
The low brake fluid indicator came on. I checked and filled the reservoir. How do I reset the indicator?
Mar 20, 2010 at 3:27 AM
HMAC300
  • 48,601 POSTS
There is no reset only low brake fluid, It is probably because you need front brake pads.
Here is a guide to help you check the pads and fill the brake fluid.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Cheers
Mar 20, 2010 at 6:06 AM
