2005 Buick La Crosse Fuel Filter
2005 BUICK LA CROSSE
MIKEJUDGE50
Engine Performance problem
2005 Buick La Crosse 6 cyl Two Wheel Drive Automatic
How do you change a fuel filter on this car
Nov 15, 2008 at 3:09 AM
  • 110,244 POSTS
Hi:
I believe the filter is located along the frame rail under the driver's seat area. All you need to do is remove the mounting bracket and the inlet and outlet lines. It's really not too hard.
Let me know if you run into problems.
Nov 15, 2008 at 12:31 PM
BRIAN 1
  • 1,030 POSTS
this one is not on the frame rail it's in the tank,this is a returnless fuel system.
Nov 16, 2008 at 1:24 AM
