2001 Buick La Crosse engine misses
2001 BUICK LA CROSSE
69,001 MILES • 6 CYL • FWD • AUTOMATIC
BLACKDOGGIE_1
my engine misses real bad when it's cold,then now and then at road speeds.
Jan 27, 2008 at 4:24 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9cc62c4b71="blackdoggie_1"]Electrical problem
2001 Buick La Crosse 6 cyl Front Wheel Drive Automatic 69001 miles
my engine misses real bad when it's cold,then now and then at road speeds.[/quote:9cc62c4b71]
is check engine light on ?
if so have it scanned for codes
as a 1st step
check for tune up
Jan 27, 2008 at 4:40 AM
RHALL77
  • 3,361 POSTS
to honest i would check for codes. most likely o2 sensor #1 pre converter. Possible pluged injectors. Does it have a secondary air injection system. there is a valve on the right side of the engine below the cylinder head that i have seen cause this to.
Mar 7, 2008 at 5:09 AM
