When driving up hill check engine light turns on
238,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MERCHQUEEN
  • 6 POSTS
My car just started flashing the check engine soon light when I try getting up a hill. I level off and the light goes off. Runs not very well up hill either. My code reader, will not give me a code. Seems to be getting worse. Help!
Dec 5, 2020 at 4:01 AM
Good morning,
You have a misfire when the light flashes.
How old are the plugs and wires? They are very common reasons for the misfire.
I would start with a set of spark plugs and see if the condition still exists.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Dec 6, 2020 at 8:38 PM
MERCHQUEEN
  • 6 POSTS
Thanks, I will start there. It was also mentioned to me, that it could be a ground. What can you tell me about that and where do I find it? Thanks again.
Dec 8, 2020 at 6:29 AM
No, it is not a ground at all. This is something else.
Dec 8, 2020 at 7:09 AM
MERCHQUEEN
  • 6 POSTS
thanks, new plugs going in now. Will let you know.
Dec 9, 2020 at 4:24 AM
You are welcome.
Always glad to help.
Dec 9, 2020 at 7:55 AM
MERCHQUEEN
  • 6 POSTS
3 plugs in today. 3 to go. 3 rear in. 3 front to go.. The all day long ones job. I needed to drive it today, for 110 miles. missed on several hills, but plugs are only half done. I will keep you posted.. you are a saint and again, thank you so much for your help!!!! You have been a bright spot in a not so bright year Expensive car repairs, I can't afford now, but I am still lucky and am an essential worker and need to work. Bless you. Thank you again...
Dec 9, 2020 at 9:06 AM
MERCHQUEEN
  • 6 POSTS
Sunday new plugs/wires. it is still missing on 2 cylinders.. antifreeze on engine also. Help do I have a car yet or not? What else can it be? Intake manifold/gasket?
Dec 13, 2020 at 8:17 AM
Okay, yes, it could be a leaking intake manifold in to one of the runners.
I would pressure test the cooling system to be sure.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/replace-intake-manifold-gasket
I attached the procedure below for you to view.
1. Remove the upper intake manifold.
2. Remove the thermostat housing.
3. Disconnect the electrical connector from the ECT.
4. Remove the drive belt tensioner.
5. Remove the EGR valve outlet pipe.
6. Remove the lower intake manifold bolts.
7. Remove the lower intake manifold.
8. Clean and inspect the lower intake manifold.
Installation Procedure
Important: In order to install the manifold, complete the following steps:
Clean the cylinder block, heads and the intake manifold sealing surface of all oil with a suitable solvent.
Apply a GM approved sealer to the ends of the intake manifold seals. Clean any adhesive compound from the intake manifold bolts and the bolt holes.
Apply thread locking compound GM P/N 12345739 (Canadian P/N 10953541) or equivalent to the intake manifold bolt threads before assembly.
1. Install the lower intake manifold gasket.
2. Install the lower intake manifold.
3. Apply Threadlocker 272 GM P/N 12345493 (Canadian P/N 10953488) to the bolt threads.
Notice: Refer to Fastener Notice in Service Precautions.
4. Install the lower intake manifold bolts.
^ Tighten the lower intake manifold bolts in sequence (1-12) to 15 Nm (11 ft. lbs.).
5. Install the EGR valve outlet pipe.
6. Install the drive belt tensioner.
7. Connect the electrical connector from the ECT.
8. Install the thermostat housing.
9. Install the upper intake manifold.
Dec 14, 2020 at 10:22 PM
MERCHQUEEN
  • 6 POSTS
Thanks, I will work on that. Let you know....
Dec 14, 2020 at 10:56 PM
