1991 Buick Electra remote mirror wiring
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROGER C. BLUME
Does anyone have a diagram of the wireing . I have the switch I have a cut off wire loom and both mirrors, but the wiring layout is unknown
May 30, 2009 at 3:26 AM
HMAC300
  • 48,601 POSTS
you need a manual for the wiring diagram, you can check your local library. but the wires are color coded so if you connect the right color wire with the one that is cut then it shouldn't be any problem. Just make sure to connect them properly and not just use squeeze connectors, try to solder them and put shrink tubing around the repair
Jan 27, 2010 at 9:24 AM
