1990 Buick Electra
PDW81375
Electrical problem
1990 Buick Electra 6 cyl
When i try and start it it just clicks..Sometimes it will start after several tries.I think its the starter or the solenoid but im not sure .Im also not sure where it is located.I think i could follow the neg terminal from battery and find it.It is a 3.8 engine.thanks for any help
Jan 8, 2010 at 11:47 AM
HMAC300
  • 48,601 POSTS
if this is a front wheel drive it will be on the front side under the exaust manifold. You can pull it off an dtaek it to an auto parts store to have t checked. Make sure you battery is charged before you pull this off first to not have any unecessary work. The auto parts can also check your battery.
Jan 10, 2010 at 7:16 AM
