1989 Buick Electra reverse
1989 BUICK ELECTRA
204,000 MILES • 6 CYL • FWD • AUTOMATIC
TWINTON
i statrted my car and put it in reverse and it wouldn't go but when i put it in drive it went. i would like to know if this means the transmission giong out or is it something else. also just yesterday i had a new pulley and waterpump put on so i could really use some help.
Mar 5, 2010 at 11:02 AM
HMAC300
  • 48,601 POSTS
check your fluid first, if it is brown or smells burnt the trans is probably toast. If it is low add to it. But it sounds like your one clutch pak is either no good or the seals are bad......
Mar 11, 2010 at 9:24 AM
