1987 Buick Electra after changing timing belt
COMERS4LIFE
Engine Mechanical problem
1987 Buick Electra 6 cyl Automatic 75423 miles
Recently changed the timing belt and timing gear on my car and now the car will crank but will not stay running what could be the problem.
Jul 3, 2010 at 9:15 AM
HMAC300
  • 48,601 POSTS
if you aligned the timing chain the correct way, you probably don't have the ignition timing set correctly. It will move even after you marked everything
Aug 30, 2010 at 6:56 AM
