1973 Buick Electra connect Actuator Rod
GENE ALLEN
Electrical problem
1973 Buick Electra V8 Two Wheel Drive 125000 miles
Dear Sir, how do I remove the upper key housing? There are three large screws below the turn signal switch. Do I remove them plus the shift handle? I'm trying to reconnect the Actuator Rod which seems too loose because I twisted it to connect to the electrical ignition switch.
Sir, how do I remove that upper housing?
Oct 25, 2008 at 8:58 AM
BUDDYCRAIGG
  • 2,262 POSTS
i need to know if you have tilt,
and/or
telescoping column
Dec 9, 2008 at 1:36 PM
