1972 Buick Electra OVERHEATED ENGINE
165,000 MILES • V8 • 2WD • AUTOMATIC
PRIVERAB
Hello, recently my buick electra started shooting white smoke out the tail pipe whenever I'd start it then it overheated on me with vapor coming out of both engine sides. I noticed the coolant was being gushed out of the radiator and back into the coolant tank where it spilled all over. I suspect I may have a blown gasket problem. How much would repair-labor only set me back on this type of a problem?
Thank you for your help.
Feb 19, 2009 at 9:36 AM
DOCFIXIT
  • 18,828 POSTS
Best I can remember it is a 6 hr job. So if your area labor rate is $90 per hour then $540 plus parts and machine work.
Feb 28, 2009 at 4:05 AM
