window will not go back up
DEEROCK27
I HAVE A BUICK CENTURY 2000 CUSTOM THE MOTOR IN THE DRIVER SIDE AND AND BACK WINDOW ON THE PASSENGER ALL WORK BUT THE WINDOW WILL NOT GO UP , I TRIED TO PULL AND YANK ON IT TO GO UP BUT WILL NOT GIVE. ANY SUGGESTIONS, OR WHAT MAY BE THE PROBLEM WILL REALLY HELP OUT ALOT . I ALSO CHECKED THE FUSES AND REPLACED THEM INCASE THAT WAS THE PROBLEM BUT NO SUCH LUCK .
Feb 5, 2007 at 4:47 AM
IDRIVEATITLIEST
  • 15 POSTS
If it quit all at once? If so the window probably came out of its frame. If the gears wore out then you could have heard it grinding when going up or down. Take it to a body shop. Those springs on the windows are very, very strong and can cause serious injury.
Feb 7, 2007 at 1:01 PM
