transmission hose leak on 1993 buick century , has 129,000
LEE MARTINEZ
my buick century has started leaking transmission fluid up front behind the radiator and when I turn my car on it starts to drip out. I noticd my transmission slipping and then noticed the small puddles of transmission fluid under the radiator. One end of the hose is easy to remove because it is attached by a clamp. The other is attached with some sort of factory clamp. How can I repair this or do I need to takeit to a transmission shop?
Sep 18, 2007 at 6:14 AM
CLY
  • 308 POSTS
Both of those hoses will come with the steal part of the line as well as the rubber part. I would recomend replacing the clamp aswell and make sure and top off that trany fluid...
Cly
Sep 20, 2007 at 10:02 PM
