2001 Buick Century Tappet Noise
EDGLR
I have a 2001 century custom. I have a noise that sounds like tappets. My mechanic has changed the springs and valves twice. The noise still persists. Oil has been changed four times, noise is still there. Any body have any ideas.
Thanks
edglr@netscape.net
Apr 18, 2007 at 1:37 PM
YELNAM
  • 8 POSTS
[quote:2faaf590dd="edglr"]I have a 2001 century custom. I have a noise that sounds like tappets. My mechanic has changed the springs and valves twice. The noise still persists. Oil has been changed four times, noise is still there. Any body have any ideas.
Thanks
edglr@netscape.net[/quote:2faaf590dd]
I have a 2001 Buick Century and the tappets are rather loud for the first minute or two. Then they quiet down. This is just the opposite of what normally should happen. When the engine is cold and the oil is thick (viscosity) the moving parts in the motor have thicker oil in them and the motor should be quiet. Why the tappets clatter is a mystery unless the hydraulic lifters dont pump up real fast. Let me know if you find anything out.
May 9, 2008 at 10:45 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:bf52adea4f="edglr"]I have a 2001 century custom. I have a noise that sounds like tappets. My mechanic has changed the springs and valves twice. The noise still persists. Oil has been changed four times, noise is still there. Any body have any ideas.
Thanks
edglr@netscape.net[/quote:bf52adea4f]
OK, in most newer vehicle the noise you are hearing are the Fuel Injectors. It is common.
Now, you say you mechanic has changed the Springs and Valve twice. Did your mechanic concider changing the lifters?
May 12, 2008 at 9:25 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:61d5e8dcec="yelnam"]
I have a 2001 Buick Century and the tappets are rather loud for the first minute or two. Then they quiet down. This is just the opposite of what normally should happen. When the engine is cold and the oil is thick (viscosity) the moving parts in the motor have thicker oil in them and the motor should be quiet. Why the tappets clatter is a mystery unless the hydraulic lifters dont pump up real fast. Let me know if you find anything out.[/quote:61d5e8dcec]
As your vehicle sits most of the oil will drain down into the pan. when you start your vehicle the oil needs to be pumped up through the engine so, there will be a tapping noise for a few seconds after start up.
May 12, 2008 at 9:31 AM
Suggested Repair
Confirm whether the noise is normal fuel-injector ticking. If it is valvetrain noise, have the hydraulic lifters checked or replaced, since springs and valves were already replaced. Brief tapping after startup can occur while oil pumps back up after draining into the pan.
Conversation Summary
The owner of a 2001 Buick Century reports persistent tappet-like noise despite two spring and valve replacements and four oil changes. Another owner describes similar noise for the first minute or two after startup. An expert says the sound on newer vehicles is often normal fuel-injector noise and asks whether the lifters were replaced. The expert also explains that oil drains into the pan while parked, so brief tapping can occur until oil pressure is restored.
