1988 buick 162000 a/t was driving the car then it just quit would not turn over waited a little while then it started right up
Aug 7, 2007 at 12:18 AM
SERVICE WRITER
✓Experienced Mechanic
Sounds like it's time for a battery. They will recharge slightly when left alone. Have it checked first, may want to have the alternater checked for output as well.
Aug 7, 2007 at 8:32 AM
FELIPE
MEMBER
[quote:a65f33ed6a="Service Writer"]Sounds like it's time for a battery. They will recharge slightly when left alone. Have it checked first, may want to have the alternater checked for output as well.[/quote:a65f33ed6a] Had battery and alterator check both are fine could it be a relay switch an I appreciate your help
Aug 11, 2007 at 3:56 AM
SERVICE WRITER
I need to take a look at the wiring skamatic...scumadic.....schamatic.....Ahhh, the wiring diagram, but there is info you didn't provide to allow me to do so.
