1998 Buick Century Bucks Under Load
GOODOLBUICK
Buick Century 98. about 120,000+ miles Car runs fine, smooth etc. Check engine light always on, but doesn't seem to be a problem....for years.
Now, car almost acts as if it's a transmission problem as it bucks going up hills and upon exceleration, not bad bucking, but almost as if it's having trouble shifting to next gear.
Drive it slow or moderate...no problem. Only when putting some sort of load on the engine.
changed all 6 spark plugs, changed trans filter and fluid. changed oil filter and fluid, was running hot, made sure radiator is up to par also.
Had a cracked head 5 years ago, had it re machined and didn't seem to have a problem until about a week ago...still hesitating/bucking.
The problem started out as "running hot" thought it was the radiator...could be a separate problem or they go together, not sure.
Help. I love my car. Otherwise it's in fantatic condition
Dec 11, 2006 at 7:45 AM
CARUNDELL
  • 602 POSTS
[quote:d4f8724cd5="goodolbuick"]Buick Centry 98. about 12000 + miles Car runs fine, smooth etc. Check engine light always on, but doesn't seem to be a problem....for years.
Now, car almost acts as if it'sa transmission problem as it bucks going up hills and upon exceleration, not bad bucking, but almost as if it's having trouble shifting to next gear.
Had a cracked head 5 years ago, had it re machined and didn't seem to have a problem until about a week ago...still hesitating/bucking.[/quote:d4f8724cd5]
Hey goodolbuick,
Sounds like it may be an ignition wire failing.
Chris
Dec 11, 2006 at 7:48 AM
GOODOLBUICK
thank you! I'm a girl so this may sound dumb. how many "ignition wires" are there? Is it hard to change? Can it be changed? Does this mean my car is dying?
Dec 11, 2006 at 7:53 AM
CARUNDELL
  • 602 POSTS
[quote:642fd70c3c="goodolbuick"]thank you! I'm a girl so this may sound dumb. how many "ignition wires" are there? Is it hard to change? Can it be changed? Does this mean my car is dying?[/quote:642fd70c3c]
LOL You don't sound dumb!!! Should be 6 of them, and you had to pull one end off to do the spark plugs. Change them one at a time and you should have no problems. Nope, your car is not dying, just needs a little TLC!!
Chris
Dec 11, 2006 at 8:01 AM
GOODOLBUICK
Thank you! thank you! THank you! :wink:
Linda
I'll let you know if that works...! Unless you dont' want to know. :cry: :lol:
Dec 11, 2006 at 8:13 AM
CARUNDELL
  • 602 POSTS
[quote:7d8beb20f0="goodolbuick"]Thank you! thank you! THank you! :wink:
Linda
I'll let you know if that works...! Unless you dont' want to know. :cry: :lol:[/quote:7d8beb20f0]
Linda,
Sure thing, drop me a line!
Chris
Dec 11, 2006 at 8:18 AM
XOWEY
  • 113 POSTS
I agree, it sounds like you have a spark plug wire problem. ignition coils on these also are a common failure, they get rusty where the plug wire connect to them. :wink:
is it running hot as a current problem? intake gaskets are a common failure on these, also ..........may be time for another thermostat after 5 years. :wink:
Dec 12, 2006 at 2:20 PM
Suggested Repair
Replace all six spark plug wires one at a time, and inspect the ignition coils for rust where the wires connect. If the engine is still running hot, also check the intake gaskets and thermostat.
Conversation Summary
A 1998 Buick Century with over 120,000 miles bucks under load or acceleration, has a long-standing check engine light, and had recently been running hot. Spark plugs, transmission fluid and filter, oil, and radiator condition were already addressed, and a cracked head was repaired years earlier. Experts suggested failing spark plug wires, rusty ignition-coil connections, and possible intake-gasket or thermostat issues if overheating continues.
