1998 Buick Century Rear Spark Plugs Fix
BC1998
Is there any special tricks to getting to the rear spark plugs to replace them?
Thanks in advance!
Apr 7, 2007 at 4:12 AM
BOOTDOG
  • 665 POSTS
if the motor has motor mounts towards the front of the car, you can take them loose and rock the engine forward to gain access to the plugs. also they're are special double swivel spark plugs available to help with the plug removal too.
Apr 7, 2007 at 8:56 AM
Suggested Repair
If the engine has front motor mounts, loosen them and rock the engine forward to reach the rear spark plugs. A double-swivel spark plug socket can also help with removal.
Conversation Summary
The owner of a 1998 Buick Century asked how to access the rear spark plugs for replacement. The expert suggested loosening front motor mounts and rocking the engine forward, and using a double-swivel spark plug socket.
