1996 Buick Century Doors Won't Unlock
DEANKY
I have a 96 buick century. The remote won't unlock the doors and neither will the key. It stopped working all of a sudden. What could be the problem? I replaced the battery in the remote and tried using the spare remote and key. Nothing worked. Help, I'm locked out!
Aug 6, 2007 at 12:48 PM
MERLIN2021
  • 17,250 POSTS
Can you unlock the passenger side?
Aug 10, 2007 at 6:50 AM
DPWD23
  • 136 POSTS
If you can't unloc any door, get a tow guy out to unlock you.
You need to take off the door pad and get to the lock mechinisims inside and lube the crap out of them. It's also possible that your switch inside is stuck to "lock". if it is, it can be hard for you to unlock with key. if that's the case, you can wait for the battery to die and try again. make sure you clean all the contacts at the controll switches inside the door.
Aug 10, 2007 at 11:19 AM
Suggested Repair
If no door can be unlocked, have a locksmith or tow service open the car. Then remove the door panel, thoroughly lubricate the lock mechanisms, check whether an interior lock switch is stuck in the lock position, and clean the contacts at the door control switches. If a switch is stuck, waiting until the battery dies may make key unlocking easier.
Conversation Summary
The owner of a 1996 Buick Century is locked out because neither the key nor the remotes will unlock the doors, even after replacing a remote battery and trying the spare remote and key. One expert asks whether the passenger door can be unlocked. Another advises having the car unlocked if no door opens, then removing the door panel to lubricate the lock mechanisms, checking for a stuck lock switch, and cleaning the door switch contacts.
