2005 Buick Century difficulty starting
77,000 MILES • 6 CYL • FWD • AUTOMATIC
D. MURRAY
About half the time when I turn on the ignition, the solenoid relay opens and closes about once a second and the dash warning lights turn on and off. Sometimes the car will start and runs roughly until the oscillation stops. Then it runs normally. Usually, it won't start while oscillating.
It has also quit while running. Sometimes it starts normally.
Thanks for your help.
Mar 6, 2010 at 10:07 AM
  • 110,251 POSTS
Are you sure you are not hearing the fuel pump replay?
Mar 12, 2010 at 5:30 AM
