cooling system service instructions please?
ANSELMOGARCIA
I need to do a coolant flush on the car, it keeps overheating.
Feb 21, 2010 at 12:35 AM
  • 110,246 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
This video shows the job being done on a similar car but the process is the same.
https://youtu.be/5ayVixLqS4E
Mar 3, 2010 at 5:15 AM
TIMZONE157
How do I drain my radiator to put fresh anti freeze in.
May 26, 2021 at 5:21 AM (Merged)
  • 55,540 POSTS
The drain plug is on the lower left tank of the radiator here is a guide and a diagram (below) to help you see what to do.
I prefer to pull off the lower radiator hose. Drains a lot faster. To drain the block you should remove the block plugs on them if possible. If not just ad water and run it through the system. And re-drain and refill with proper coolant.
Check out the diagrams (Below)
Cheers, Ken
IGGYSBUICK
Could you please tell me where the radiator drain is located on my 2000 century. thanks so much
iggy
IMPALASS
  • 3,112 POSTS
Hello It should be located at the lower drivers side of the radiator.
https://images.2carpros.com/forum/automotive_pictures/248015_84980747_1.gif
Hope this helps
D FURMAN
Where is the drain for the Radiator. or does it have one?
  • 110,246 POSTS
It should be on the lower driver's side. It will look like a wing nut. If there isn't one, you may have to remove the lower radiator hose to drain the system.
