2004 Buick Century driver's door panel removal
2004 BUICK CENTURY
DENNIS51944
Interior problem
2004 Buick Century Front Wheel Drive
I've removed the power window/power mirror switch and have disconnected the electrical connections. I've also disconnected the power door lock switch. Obviously to accomplish this I unpinned the door panel around the perimeter. Still I can't remove the panel. Something that I am unable to see in the middle of the panel is holding it. I don't know if it's more pins or if it's something else. I don't want to force it. Should the arm rest that held the power window/power mirror have been removed? If so, is it pinned on? Should it be pried off? I'm trying to resolve a problem with the power window on the driver's side which may bring up further questions.
Thank you for your help,
Dennis Jackson
Jul 9, 2010 at 10:23 AM
JALOPYPAPA
  • 467 POSTS
Usually the art rest has to be unscrewed from the door frame. Look underneath and check for any recessed screws, perhaps hidden under pry-out plugs. There's also typically a screw under the door latch handle.
Jul 12, 2010 at 3:05 PM
