2003 Buick Century wiper fluid reservour
133,000 MILES • 6 CYL • FWD • AUTOMATIC
PAULDG0
My windshield wiper reservoir split when I hit a large rock on my right bumper. It has not been used in some time. I do not hear my pump moter working now...maybe it seized up over time...I don't know.
Can I fix the tank without buying a new one. Is there a sealer out there somewhere?
I do not have funds to buy a expensive new tank.
Please help??
Jul 4, 2009 at 5:20 AM
  • 110,248 POSTS
If the tank only has a slight crack, you may be able to fix it with a plastic epoxy. However, I can't guarantee it will work. You could get one from a junk yard for cheap. You may want to try that. Also, as far as the pump, you need to check for power to the motor. IF it's getting power, replace the motor.
Jul 18, 2009 at 10:39 AM
