6-way power driver's seat will not move forward by operating the switch, but operates all other directions
Feb 13, 2010 at 6:13 AM
✓Experienced Mechanic
Chances are the switch is bad. What you need to check is if there is power going to the motor when you use the switch to go forward and backward. Here is a guide to show you how to replace the switch.
Yep you were right I replaced the switch I got for $43.00 everything is fixed! Thanks for the reply.
Feb 14, 2010 at 7:26 AM
