2003 Buick Century milage indicator, shifter indicator and
TOM CLANCY
Electrical problem
2003 Buick Century 6 cyl Two Wheel Drive Automatic
The milage inidcator and what gear it is in does not light up all the time and the keyless entry to the trunk does not work all the time. I have replaced the battery for the keyless entry but everything still works intermitently.
Jul 5, 2010 at 7:43 AM
EDWARD.S
  • 166 POSTS
Hi, You Need To Remove The cluster And Send It Out for Repair.At The Speedometer Shop. You Cannot service Or replace Bulbs .It is A Florscent Display.
Hope This Helps You.
Good Luck
Edward S.
Jul 19, 2010 at 12:57 PM
