2003 Buick Century lower motor mount
2003 BUICK CENTURY
DIANA KRESSER
Shakes or Wobbles problem
2003 Buick Century 6 cyl
when replacing a cat. converter would adjusting the lower motor mount be necessary? how would i tighten a loose lower motor mount?
Apr 20, 2009 at 10:41 PM
  • 110,244 POSTS
Hi:
The converter is part of the exhaust and has nothing to do with the motor mount. If the mount is worn and causing it to be loose, it needs replaced. Make sure the bolts are tight on the mount.
Apr 22, 2009 at 10:24 AM
